While removing the front fairing on my bike, I broke a couple of those plastic expansion rivet-type fasteners on the cover underneath the headlights. Does anyone know where I can get some replacements? A big bag of assorted fasteners would be good, I can see I'll probably break some more in the future. :)
M
I bought a few in pairs from my local dealer, about $2 for a couple pair.
m
Napa carries them. If you want the part numbers let me know, I dont have them right handy at the moment.
cheers
Here are the Suzuki part numbers.
  • 09409-06314-5PK --- $1.62
    09409-07333 --------- $1.38
The first number is for the smaller fasteners, 5 per package.
The second number is for the larger fasteners that are under the front cowling.
I just ordered some along with a lot of other stuff from www.mrcycles to repair my crashed Wee-Strom :(
Mike
Tampa, FL
DL650K5
G
I actually found some at my local Lowes in the bolts drawer section. Shocked me.. only had one in there though.. and it fit.
Thanks for the part numbers. Right now I'm using some automotive fasteners, but they aren't quite the right size and don't hold tight enough. I'll order some proper ones.
I've since learned the trick to getting these out undamaged. If you push the center button in, the rivet will release. I tried to pry that button out, and tore up a couple in the process. :oops:
