So I bought my 2002 at the end of the fall in 2019, and I only got a few rides in before the winter set in. I had to address a couple things right away. It had a bad pop/backfire upon deceleration, which I found to be the seal on the rear cylinder exhaust pipe. I redid the exhaust and changed the mufflers, then rode it until the salt hit the streets.
Over that winter, I replaced the tires, the chain and sprockets, did the rear wheel spacer mod, did the Werks clutch basket, replaced the broken turn signals, and a bunch of other minor stuff.
Rode through this past summer and it was good for the most part. A few running stumbles and it's always felt rough. Been playing with the TFI adjustments to hone in on it. I added a voltmeter and an Admore lighting kit to the topcase over the summer, and decided to tear it down for real and go through it. Removed the necessary fairing pieces and the radiator so I can check/adjust the valves. Checked and torqued the slack adjusters. I have already cleaned up some of the wiring under the seat, but I got a good laugh this afternoon that had me shaking my head. One of the previous owners added a compact air horn. I knew where it was, and there was a relay strapped to the side of it, so I figured it was done fairly well. I was mistaken. Whoever added it unplugged the factory horn and used that for power and ground. No other power source, though. They literally powered the latching coil of the relay and the load circuit of the relay with the factory horn connector and circuit. So, in effect, they actually added even more load than they would have if they had just run the factory wires right to the air horn motor with the minor amount of load from the relay. Well done
. How it actually worked, I don't know. I also found that the grip heater controller was wired directly to the battery. I just about gutted all of the added accessory wiring this afternoon so I can redo it correctly. I figure that the Strom isn't worth much, cash wise, these days. May as well get it as correct and reliable as possible and ride it all over the place. Even when it isn't exactly right, it's still a hoot to ride.
