Wheel Valve stem size
1238 Views 12 Replies 8 Participants Last post by  Brockie
With all the knowledge on Stromtrooper, I'm hoping that someone knows the answer.
I'm getting ready to change tires on my 09 Wee and figured is was time to change the valve stems too. I just can't remember the size, it has to do with the diameter of the hole.
Is it a TR 413,TR 415 another size? I'd rather get them before I start that wait to remove the tire and read the number on the inside of the stem.
See less See more
1 - 2 of 13 Posts
The TR-413, but I would highly recommend angled steel valve stems.
You will thank yourself every time you pump up your tires.
I use 90 degree valve stems. 45 degrees for those with wire wheels.
Rectangle Font Circle Number Magenta
See less See more
Reactions: 2
My 90 degree valve stems were fitted in 2015. Zero issues so far.
Reactions: 1
1 - 2 of 13 Posts
