1 - 4 of 4 Posts
I ordered a part for my 06, I ordered the lower of the two on the fich, #7 is 13580-02F00. The part did not work as the primary , I measured the value and its 5K ohm down to 900 ohm.
I then ordered the part #3 13580-06G00 , I am about to find out what its values are.
the following is for 13589-02F00
Update: Received the -06G00 and it is for the secondary's, the connector has 4 pins, The range is 4.88K . So item #3 is for the secondary's. and I am returning it to the Vendor and reorder the -02F00 or #7 on the micrfich.
I see a manufactures number on the part -219930-
the number on the box (not the Suzuki #) 191023
ohm range 5K to 900 ohms (should be 4K to 900)
Anyone have their old parts laying around and can post what number they have on theirs?
In the old days dealers had parts in inventory , you could pick up the part and compare it to what you took off before you bought it. I just dropped $160 on experments. Before I do anything with the next part I am going to measure the resistance to see if its within the factory specs.
I'm trying to figure out how to tell its the correct part by looking at the manufactures number. I believe I have a wrong part in the right box.
1 - 4 of 4 Posts
