What's the lowest Air Temp the cluster shows?
3734 Views 19 Replies 13 Participants Last post by  kballowe
2
Tonight I was trying to take a photo of my Vstrom out in the snow and for the first time saw the temperature show "Lo" instead of something numeric.
Does anyone know what the lowest threshold is on the dashboard/cluster's temp display?
Just curious... Because it was -7 degrees F. (we are going through the vortex thing).
Also, incase anyone wonders, the Vstrom will fire up and run very well at -7 degrees F. (This is -22 degrees C)
Automotive lighting Vehicle Gauge Motor vehicle Speedometer
Photo of my Canon R5 after coming back into the house. Never seen it freeze over like this, but it worked fine. My iPhone, on the other hand, did not make it and died outside.
Mirrorless interchangeable-lens camera Reflex camera Point-and-shoot camera Digital SLR Camera lens
See less See more
  • Wow
  • Haha
Reactions: 5
1 - 20 of 20 Posts
I'm not sure but I think I remember the snow flake showing up at 3c but hey I'm a Aussie so we have to look hard to find temperatures that low.
I think it's right around 9 degrees F.
I think on my bikes it says/ said "lo" around -10c
Reactions: 1
Too cold for my worries. Never had a bike with a snowflake on the gauges before.
I hope you got it warm enough to burn off any combustion water/moisture before turning it off.
also your tank should be full, preferably with non ethanol or treated fuel. or you may find yourself with a rusty tank come spring.
Reactions: 1
Nope, I didn't have time to worry about the list of concerns you mentioned lol
The snowflake comes on at 38 degrees F. When I first saw it on I thought it just meant I was a special snowflake like the rest of society thinks they are. Turns out it means it's cold and your a dumbass, they just thought it was more politically correct to put the idiot light instead of a dumbass light. :)
  • Wow
Reactions: 2
38°f/4°c is the temperature that ice is completely thawed
between 32°f/38° is the temp where there are the most unknowns
BUT, in winter, air temp can be 50° and road surface temp still way below freezing, snowbanks melting, and refreezing into black ice as it drains across the road, and salt can turn ice into liquid
I put studs in my tires, riding in blizzards is relaxing, no traffic except a few snowplows
  • Wow
Reactions: 2
If we got enough snow where I am I would love to have a set of studded motorcycle tires and try winter riding.
Reactions: 1
That’s one thing I will never know.
Reactions: 1
2
Years ago I had a DR250S with dirt knobbies on it. Getting ready for "The Elephant Ride" here in Colorado, where we ride up Guanella Pass (11669 ft) (was dirt then) in February, I studded the tires. !/4 inch sheet metal screws in the knobs of the tires. Worked great on the Ice and snow, not so much on the dry pavement. Was a blast. Then a few years back CDOT paved the Pass. End of the Elephant Ride. Was a tribute to Hannible crossing the Alps.
Tire Wheel Land vehicle Vehicle Automotive tire
Snow Vertebrate Sky Mountain Motor vehicle
See less See more
Reactions: 2
Years ago I had a DR250S with dirt knobbies on it. Getting ready for "The Elephant Ride" here in Colorado, where we ride up Guanella Pass (was dirt then) in February, I studded the tires. !/4 inch sheet metal screws in the knobs of the tires. Worked great on the Ice and snow, not so much on the dry pavement. Was a blast. Then a few years back CDOT paved the Pass. End of the Elephant Ride. Was a tribute of Hannible crossing the Alps.
View attachment 310936 View attachment 310937
Sounds like a lot of fun. I bet the bike gets a little squirrelly on pavement riding on studs doesn't it?
Reactions: 1
14º F. That may be the lowest reading the sensor can produce. I've never noticed, but I would think that the display would be capable of -888 (all 25 segments). If I think of it when it warms up a little, I'll go out and try to photograph it while it's booting up.
sheet metal screws or ice screws work well when riding on a pond, but not the street. I drilled stud pockets, and inserted automotive studs with a pneumatic stud gun, a little sketchy the first 50 miles or so till the studs get seated in, not like molded stud pockets like car tires. but once they are seated, it's just like studded car tires on dry pavement tic tic tic
Tire Wheel Automotive tire Tread Synthetic rubber
See less See more
Reactions: 2
I think that the oil in your bike's engine is not designed to operate at such low ambient temperatures. Every time you start your engine, it's under a lot of stress, and negative temperatures only make it worse. Be careful.
P.S. I know a thing or two about the real cold)
I know it's not "real Cold" but my bikes have ridden fine down to 0f and below with no issues. They've also ran all day in the teens F. My last Strom was a 2015 DL1000 which I sold at 235,000 km and it was running fine. My 2006 DL650 had the same treatment and was running fine at over 200,000 km. I generally am running 5w40 in winter.
Here's my photo from the Elephant ride circa ~1996 (maybe '97?).
Wheel Tire Land vehicle Vehicle Sky
I had a 1992 BMW R100GS. My partner had a Trans-alp with home-made chains.
I had no traction aids - just those Michelin stock tires. I lost track of how many times I had to pick it up that day. it was like every single switchback - I'd fishtail and bang, down I went. I was the last guy to make it into Georgetown that day. Oh my aching back!
Man I'd love to try that again.! Thanks for the memory.
See less See more
Reactions: 3
3
I remember the Trans Alp with the chains. One year there was also a Yamaha Venture with cleats on his tires. He trailered to Grant. If I remember correctly I went three years Feb 97-98-99
In 97 I brought my camper and DR250, 98 I brought both my Dr250 and my BMW r100gspd, and 99 we had just moved to Texas and I drove up and trailered my BMW.
See less See more
22F is the lowest I've seen on mine.
1 - 20 of 20 Posts
