1 - 20 of 43 Posts
Picked up the new bike today. 2018 1000xt. Put around 90 miles on it. 25 of those with the wife. She is 5’6 and about 150 lbs. Within 5 min she said she doesn’t like not having a backrest. She is use to riding our Harley cvo road glide with top box.
So I have researched most the night on the forum and have confused myself. 😫
Here is what I’m looking for...
Top box that will look good and not out of proportion with the bike.
She doesn’t want it to make her feel cramped or any closer to me. Prefer it not push her forward or make her lean forward. It would be great if we could fit 1 medium modular helmet and another xxl modular without being to big. Reference 1st comment on looking good with bike
It needs to work with future side cases.
I like the look of the Givi v47 tech top case, but didn’t know if it takes up passenger seat space or causes pillion to lean forward.
Also are there any differences in mounts? Givi vs Motech etc.
Appreciate feedback and direction.
I got a bit of a dog cussing for not having a top case. 😂
Whatever box You use, ensure that the plastic carrier is well braced from underneath because it is too flexible to support a top box that is being used and relied upon as a backrest. I have used a combination of a GIVI Strom-specific kit together with a very old small top box that has been used on many bikes. I tried others but the Wife settled on that set up as being the most comfortable.
Two pics attached.
Two pics attached.
imho the best rack is the givi because of the side supports. No plastic...all metal here:
The Givi outback trekker 58 held 2 helmets or 1 helmet and ALL my riding gear...strong and secure.
I never got it but Givi sells a back rest pad for this case but it's @$80 you could probably make a better one for $20.
Totally agree and that is what I also used albeit instead of the alloy plate I used the Universal Givi plate. There is actually plastic involved on your carrier though and that is the OEM Suzuki item under the alloy plate. That is the item I refer to as being flexible. You will see from my photos that I am also using the Givi side supports.
If you want to go cheaper but still functional and low profile, then a Pelican box is the answer. I do not have a pad on mine and the wife says it's comfortable,, but if she is going to ride long distance I would add a pad.
MacDoc don’t have any side cases, I’m starting from scratch with new bike.
One of previous bikes was a bmw 1200 gsa with Aluminium top box and side cases. I liked the loading from the top. I know Givi has the trekker series that loads from the top.
I’m going to start with top box and then get side cases later this summer.
I like the Shad and how it mounts to the bike, but should I be concerned of of how the top mount works with Shad set-up vs Givi that has the side brackets?
Shad vs Givi- does either have a benefit in giving passenger more room? Meaning does one sit farther back vs the other?
Am I over thinking this? 🤓
Just want to purchase once and cry once. Fear is I will get a top case and it will push her forward or cause her to lean forward.
Motorcycling was so much easier when I was single. 😄
Luggage is important but I like Shad quality tho I have no arguments with Givi ...I think Shad a step up.
You are overthinking the top case.
This is really nice -expandible
https://www.revzilla.com/motorcycle/shad-sh59x-expandable-top-case?rrec=true
Side cases are another story...
I really like my Shad SH23 - they weigh nothing ( 3 lb each ) and the 3P mounting system is almost invisible when the cases are off.
This is what the 3p looks like on yours
The whole luggage on mine adds only 10 lb to the bike when not loaded - mounts and side cases and looks decent.
Yup - much easier solo >:)
46 L total might not be enough for you. Tho with a 48-50 L top case might be fine.
I was very pleased with the cost
https://www.revzilla.com/motorcycle/shad-sh23-side-cases
I think I was $400 US cases and rack.
Yours would be about $450 - rack and cases.
https://www.revzilla.com/motorcycle/shad-3p-system-side-case-racks-suzuki-v-strom-1000-xt-2014-2018
I noticed Revzilla has a good deal on the SH35s $200 off.
https://www.revzilla.com/motorcycle/shad-sh35-side-cases
BTW we had a top case rack on my kids bike and it was great for drying clothes or strapping on light stuff,
https://www.shad.co.uk/product/5141/top-box-luggage-rack
The kid always had socks etc drying
I have an 07 V with stock top/side cases.
My son rides with me and complained about how tight the top case made the ride.
So I fabricated a metal bracket and remounted the top case 2.5" to the rear of the bike.
One note: I noticed if you cannot remove the seat without removing the top case, then the top case is too far forward (especially for passengers).
I would worry about that pushing forward thing with most top boxes. I remember reading a long time ago of a guy who had to build a custom plate to hold his top box, just to satisfy his wife. I guess she was a little larger around the middle, or maybe he was larger around the middle, and she was getting a bit squished.
One idea is, add a Givi plate, then rig up some kind of back rest to it, so your wife can test it, before you buy any top box. Sort out the needed distance first. If you get a decent back rest, maybe you won't need the top box at all.
Next problem is, if you want to fit two helmets inside a top box, it is going to need to be a really large box. I doubt those shad boxes would fit an xxl and a medium at the same time, but I could be wrong. You might need to go to a 58l to fit everything.
I have the Shad SH48 top case with the pad kit and the Shad SH23 side cases. I built my own adapter plate and side braces for the rear rack. (absolutely, YES, add some bracing to the OEM rear rack because it's a flimsy thing.) In all, it's a pretty good set up.
My wife is 5-8 with long legs. She is not cramped with the rear case.
Keep in mind that even with the SH48 and backrest, your XT will not be comparable to a Goldwing or other nicely appointed bikes.
Here is what I like about my Shad top & side cases:
a- The Shad top case can be opened & latched without locking/unlocking the latch set. It can be locked only when I want.
b- The side cases are top loading, and very sturdy.
c- The Shad side rack mounting system is a very positive lock- much more secure than the Givi system which I had on my past 650.
d- The top of the Shad side cases are a little bit lower than the Givi cases.
e- The Shad side cases are supplied with an extra key lockset so that the top case will use the same key as the side cases.
f- The SH48 passenger pad set is the best I found when shopping.
On the downside, the Shad side case mount system is sort of a contraption where it mounts to the upper sides of the bike. The kit comes with fairly long spacers which cantilever the screws too far out. In the event of a tip over, parts could get bent. I should think of some better bracing maybe. Not sure if the Givi system is any better though.
Discussion Starter #15
Bazooka Joe. Do you have any pics of additional bracing you put in? Thanks for the pic, it helps since we have same color of bike.
I like how the Givi mount has the side bracing. Will I have problems if I don’t do the additional bracing? Anyone?
Between the Shad 48 and the Givi 47, are my chances slim that I can get 1 medium modular and a xxl modular in there?
You have to be careful in loading a top case ...that said I've owned several, overloaded them all and never had an issue with standard mounting brackets. The expandable Shad I think handles two helmets.
CaptainMorgan,
Sure- Here's some more pics to show how I did mine. My adapter plate is 1/8" aluminum and the side braces are also aluminum. Your connection to the side case mount will probably be different though.
I rode for a while without the side braces, but the rack is pretty flimsy and the case bounced quite a bit. I think at some time, the rack would eventually crack- the rack is only made of tough plastic.
Pretty sure you can get the helmets in there. I'll try tomorrow with a couple of XL full face helmets and report back with a picture.
Hope this helps.
Discussion Starter #18
Bazooka Joe. Thanks for taking the time with the pics. Gives me a better idea of what would need to be to done to make it a solid set-up.
In a perfect world it would be nice to have the Givi mount with side braces (no fabrication needed) and then be able to use the Shad top case. I do like you set-up with all the Shad bags. I just need to figure out if I want to figure out where to get the aluminum brave work done.
Appreciate you checking on if two helmets will fit in top case.
I really think you are over thinking it...top cases are not designed for heavy loads and Shad engineers their fitments very well.
That's a solid rack on the Vstrom as well unlike some of the bikes like mine with no rack at all.
This is a really good top case for your requirement for two helmets....it expands and I think you'll find the Shad mounting system top notch.
Low profile when collapsed
then full open.
Case SH58X - Top Cases - Shad - Engineered for riding
I don't know about front to back adjustment ....you could email Shad support....they've been very good.
Imho if the top box is lightly loaded the standard carrier unbraced might be ok. When I first mounted a top box on the Strom carrier I tested the box mount by straining it against the mount and I was immediately surprised at the extent to which the carrier flexed. Long term over rough roads even lightly loaded I believe that carrier could eventually break. Under no circumstances would I carry a pillion who uses the topbox as a backrest without bracing. As such I believe braces should be employed either home made like Bazooka Joe's or branded.
1 - 20 of 43 Posts
