Because a twin 650 runs smoother than a twin 1000. Smaller bores with less reciprocating mass.
Similarly, an in-line four 1000 is smoother than a twin 1000.
What is primary balance?Plus being a 90 degree v-twin gives it perfect primary balance. I know this applies to both the Vee and Wee but smaller pistons and stroke on the Wee will make it feel sweeter.
I'm not sure what was in there when I got the bike but I changed the oil last month with full synthetic. The shifting is still a little rough at times.If you are not doing so, try running full synthetic in your engine.
Certainly smoothed out my shifting.
Try not fully shutting the throttle when changing gears, that should smooth things out.I see. It certainly does feel like a smooth-operating machine...except for when the shifting gets...jerky. I still haven't figured that out after all this time but then again, I've never really looked much into it. I guess that doesn't really have anything to do with the engine itself anyway.
Thanks, I'll try that.Try not fully shutting the throttle when changing gears, that should smooth things out.
+1I think my 2016 1000 engine is a gem![]()
