4401 - 4420 of 4421 Posts
Installed a new bar, a Renthal Street bar medium. The OEM bar looks like it may have been tweeked at some point in the last seven years.
I fitted panniers. Budget: AU$700 (Suzuki ones are about $1200) but you can get after market ones for around $700. Expenditure so far $24 for a 1m piece of aluminium angle iron & a few bolts. My sister gave me the mini suit cases. They're the perfect size & hard plastic (not cardboard). They came from a 2nd hand shop
. $13 for a can of black spray paint is a bit of an indulgence but what the hell. Smugness factor high.
275592
What brand is air seat and how do you like it? Does it eliminate numbness?
Was going to go with the Air Hawk, but I figured I try a low cost version first to see if it helps to eliminate the vibs I was feeling in the standard seat. I live in a small town with plenty of back roads that are not very well paved, now I was only gone for 20 mins but I purposely drove my bike in 4th gear between 4500-6000 rpm (where I feel the most vibs) and made no attempts to avoid potholes. It was an odd feeling at first sitting on a pocket of air. You tend to move around more in the saddle as you weight shifts on the small pockets. But I can honestly say that I could not feel the vibs in the seat (yes eliminated) and I was amazed how comfortable it was going over a rough section of road. The downside is it adds 1/2 inch to the seat height and at 5'.7" it means I am on my tippy toes. (I did order an Adventure Tech lowering link 7/8" and will share my thoughts after I get them installed.)
Here is the link to the air seat I purchased on Amazon.ca Wehope Sport Motorcycle Cruiser Seat Air Cushion Pad Fits Most Seats of Sport Touring, 11" L x 11" W, Accessories - Amazon Canada
Let me know if you have any other questions.
Nice! I think I might need up and back risers. Did you have any difficulty with the cables being too short?
I did have to cut the zip ties holding the left switch housing controls wiring on the bar and lower down where its connected to the clutch cable. The other thing I did was rotate the handle bars up and back slightly to create more slack. It's tight when I turn the handlebars full lock to the right but should be fine. The benefit is I am not leaning forward.
This is the air cushion that I bought for my Honda VTX 1300 and it worked well. I tried it on my new 650XT today for a bit and I'll have to fiddle with the air pressure to get the right mix but it fits well. It comes with a hand pump to achieve the desired level of air cushioning. They even include a little water pump to fill the seat with water should that be your choice, though I don't think that would be a good idea long-term. https://www.amazon.com/gp/product/B07TJQBJYF/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
I bought that one as well as my airhawk sprung a very tiny leak. I found on a very long ride (450 miles) it didn't perform as well as the original. And I also found the seat just too narrow for my taste. But I've heard that you need to switch out an air pad and a gel pad and something like lamb skin every fill up if you want to relieve pain.
Thanks Focus - my issue is I get numb/sore after a while. I'm sure an after-market seat would cure it but it's such a gamble to spend $$ and not have a test ride first.
Farkle Purchasing System
Got the sticky clutch issue sorted - mostly.
There was debris lodged in the upper banjo bolt. Swapped with OE banjo bolts, fluid refilled & bled, problem solved for now.
Going to rebuild the MC, once parts get here. Jury's still out but I suspect something inside the MC was shedding rubber. I don't know how else you get debris inside the upper BB but not the lower one.
I'm gonna try the low seat option along with the air seat to see if I can get my feet closer to the ground.
Oil change!
Learned how to get a stuck crush washer off the drain bolt
Motul 300v 10w40
OEM filter
Loving the fact I don't have to wrestle with fairings to do maintenance
Just a bath! And moved it from outbuilding to another.
Reactions: DesertBike
What do you use to clean the wheels?
I seem to have a hell of a time getting them truly clean. Dust accumulates from unpaved rods, and it seems to stick like glue.
Sticking to the chain lube? First, I use a dry silicon chain lube where I have less of that problem. Then good ol' automotive brake cleaner. Be careful and wash it off afterward so you don't mess up the paint!
Try this stuff. Makes short work of the MC wheels. I bought it originally for my wifes Audi because the stock pads would just coat everything in brake dust.
Interesting. I've tried Meguiar's car wash, but it doesn't quite do the job.
