When I purchased my used DL650, it had been lowered quite a bit. I have since moved it back to stock. However, it sure seems to lean more that it should when on the side stand and the base does not lay flush to the ground. I was at the dealer the other day and looked at one on the showroom floor and it appeared longer and the bike leaned less. I read a lot around here where people have them cut/welded. I don't see signs of this, but am not sure.
What is the actual length of the stock side stand? If mine has been cut, is it best to just replace it with OEM or are there preferred aftermarket version? I don't have a center stand as of yet, but do intend to put one on in the next year.
Thanks in advance!
