1 - 6 of 6 Posts
Well I crashed the Wee once more! Yeah I know stop doing that! My problem is that I have dumped it twice on the clutch side and the interlock connector plugs have come off both times, because of the OEM guards ripping the connectors off! (first time I pushed it a mile home before I figured out what happened!) I want to replace the guards with something that wont do that before the switch gets destroyed. Any Ideas? I have Protaper ATV medium bend with an inch cut from both sides.
1
You want to do the Cycra's with the U-Clamp mounts.
Go all out and do the threaded taps into the handlebars...not the expanding thing.
That's what I did, and they worked great.
I have the Pro Taper ATV Highs.
Call Cycra, they will hook you up!!!
1 - 6 of 6 Posts
