Updated...more help: what did I do....bike refuses to run
So here is what I did on Saturday to my 2003 dl 1000 with 78,000 miles:
*new battery
*new plugs
*cleaned the k and n filter and oiled it
I put everything back together and ran the bike up the road for 5 minutes with zero issues. Then i pulled into the garage and the bike stalled, I restarted it but it kept trying to die, blipping the throttle causes it to hang at 3000 rpm and then it slowly drops until it dies again. Running the bike at 4000rpm causes it to surge like mad, sputter, pre-fire and back fire. If you put the bike in gear it refuses to run. I've checked the throttle sync, the tps setting, the tightness of the boots, checked and rechecked all the vacuum lines. Without the airbox in place it runs slightly better but still sucks and even removed the secondaries with low hopes of change and of course no change. I've cleaned the throttle bodies, ran seafoam through them and still nothing.
I'm thinking about replacing the tp sensor and if that doesn't work then throwing it in the trailer and off to the shop for the first time ever!
Thoughts?
*new battery
*new plugs
Thoughts?
