Recently my bike has started "wallowing" in high-g cornering. Meaning, I'm cornering hard, and there's a point where the bike seems to start moving side-to-side. It "feels" like it's coming from the back, but not necessarily. It isn't a "tank slapper" as the bars seem to move only an inch or two, in response to what the bike is doing. This also happens in a straight line when approaching triple digit speeds...specifically, above 95mph.
This is only a recent development; previous to it starting I could go to redline in 6th and it was solid and stright; I could corner until my curb feelers touched down, and it was solid and never wiggled.
A couple things have changed on the bike before this started happening: Steering head bearings swapped for tapered roller bearings, bald shinko 805 rear replaced with new shinko 805 rear. (The whole "bent rim" saga happened way after the wallowing started.) After the wallowing started I have adjusted the tension on the steering head bearings - both looser and tighter - and that hasn't changed the wallowing at all.
(Interestingly, the wallowing didn't start as soon as the above changes were made; it was a month or so after the changes before the wallowing started. )
I also noticed some time in that area that the rebound "clicker" screw in my rear shock doesn't work; it just spins forever in both directions.
I'm kinda stumped, so I'm open to suggestions!
I'll be getting a new set of tires soon (as my "new" 805 rear is now bald after 4k miles), so it'll be interesting to see if that helps.
