I've searched the site to no avail.
Under the seat, under the upper frame rail on the right side there are two connectors taped together. The lower one is a tapered cylindrical shape with a tit on the end (to use technical jargon). Above it is a white square connector with two green wires going into it, and a black plug on the end.
One of them is probably in case you want to install and hook up some aftermarket muffler bearings. The other one may be to recharge your blinker fluid and/or halogen fluid, if those start to run down.
@Northern Pike I thought the square one was the tip over sensor (but I'm probably wrong. ) The other looks vaguely familiar but I can think of what it might be.
The square one has 2 green wires going into it. One of them has a broken silver trace on it.
I thought the conical one looked like it could be a tip over sensor. Perhaps someone with a wiring diagram may eventually read this.
Pretty sure the one is an aux (switched) power for accessories, similar to the one under the tank for heated grips. Could plug in heated underwear, etc.
I've done a little reading too, and I'm pretty sure the ABS diagnostic connector is more to the rear, taped to the harness leading to the rear lights. It is white, with a plug with two black dots on it.
1 - 10 of 10 Posts
StromTrooper
A forum community dedicated to all Suzuki Strom owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, purchasing, reviews, accessories, maintenance, and more!
