i tweaked the left bar on my wee in a recently lay-down. i would like to replace the bent bars with a stronger set of aftermarket bars. the stock bars are fine as far as riding position goes, so i would like for the new bars to feel about the same, height, angle, and pullback-wise. i would also like to be able to use the stock handguards and bar ends. what is the best choice?
thanks
chan
I have the protaper contour bars. they're fatter than standard bars and require clamps that drop into the stock tripple clamp. the wole set up is around 90.00. i have used protapers on other bikes and have had great luck with them. search around the forum a bit and you will see what people say about the protaper SE bars that are same diameter to the stock bars and offer a more comfortable position. when you go with aluminum bars you have to modify your inner tube hardware by filing the nuts down, since the inside dia in aluminum bars is smaller than steel.
Crazy Old Guy
If you like the stock bars, why don't you just put OEM bars back on?
oneidasuzuki.com have them for 47.99 I think.
Off Wee-ing in the woods
If you want stock bars let me know. I've got a one setting on a shelf.
