1 - 4 of 4 Posts
Hey Guys,
I just recently bought my first every bike, a 2008 DL1000, and I am loving it. This weekend I did the first maintenance at 1000km. With that, I changed the oil and filter and replaced it with the Suzuki dino 10W40 and a Suzuki filter. I took it out for a spin yesterday and noticed a strange vibrating noise coming from the motor. When I got it home, I put my ear down by the motor a give it a few revs. It definitely sounds like it is coming from the block (or that area). It occurs when in gear or not and through a wide range of RPM.
Does anyone have any idea what might be causing this? Or is it something normal? Should I have used a different oil &/or filter, different viscosity maybe. Any help you can provide me with will be greatly appreciated as I am new to the game... This is also my first post. Thanks.
The oil you used is fine. Unless you grossly under or over filled the crankcase, you're probably hearing normal noises. It's barely broken-in, it will run smoother and quieter as time goes by.
Good to know Kenneth and thanks. Its my first bike (ever) so I'm not sure what is normal and what isn't.
Mine gets noises that seem to come and go. I am being honest when I say that wearing earplugs will increase your enjoyment of the bike.
That said, just check for loose bolts.
1 - 4 of 4 Posts
