1 - 9 of 9 Posts
Ok, so a couple of weeks ago I was doing a long ride with lots of dirt. I came out of a gully and gave it some gas. I was in the wrong gear and the bike lugged and started to make a strange knocking. It is still making the noise, some times quite noticeable, other times not at all. The noise seems to be timed to the wheel rotation and usually happens most noticeably in first or second gear under load.
I feel no hesitation, so I don't think it's an engine issue. Transmission, wheel bearings?
Help!
· Evolving Curmudgeon
Lift the bike off the ground and spin each wheel. Once you've narrowed it down to front or back you can start eliminating suspected components one at a time. For example, if it's a front end noise remove one caliper and spin the wheel. Noise still there? Do the other side, etc.
1 - 9 of 9 Posts
