1 - 3 of 3 Posts
Put in a new set of LED headlights.
When you first turn on the key, the lights start on low beams.
When you hit the high beam switch, they come up fine.
BUT...they won't turn back down to low with the switch.
If you turn off the key, they will restart on low, BUT same as above.
Any ideas?? Thanks!
Did you wire through a harness? If so double check the wiring.
Sounds like the relay is getting voltage feed back to the coil keeping it energized.
I have the EB headlight harness and when I put in the LEDs all worked just like before.
Mine's an 04 so maybe some wiring differences?
1 - 3 of 3 Posts
