It has a fast idle mechanism. Maybe yours isn't set right, you don't start your engine in cold weather or you forgot it starts out faster in cold.My 08 dl650a doesn't have a "fast idle".
No matter the weather or temperature outside, it always idles at 1400rpm.
I've never had an injected bike, just cars. I actually wanted injection so I wouldn't have to fiddle with jetting etc. The downside is if something is wrong, it needs a dealer.:headbang:I have no desire to own a bike without an idle adjustment screw, and can't see why anyone would purchase one. :thumbdown:
The bike is smarter about setting the idle than the user is. It would still work fine if the PO didn't touch the wrong thing.I have no desire to own a bike without an idle adjustment screw, and can't see why anyone would purchase one. :thumbdown:
It has an enrichment mechanism for sure (the computer takes care of that),It has a fast idle mechanism. Maybe yours isn't set right, you don't start your engine in cold weather or you forgot it starts out faster in cold.
The PO mentioned that the bike had been tipped over, so I assumed the oil in the airbox happened at that time. There is a crankcase vent into the airbox through a coalescing filter, and there is an oil drain back into the sump. It even looks like there is an overflow drain.My 09 Wee started fast idling recently . The weather was damp and I had been running the bike very easy for a change. You mentioned oil in the Air Box, makes me think you might have overfilled the oil when changed or someone did. I had my oil changed at a shop recently and they overfilled it. Now I too have a fast idle but only intermittendly . I am going to pull my air box off next and check it for oil .
:yesnod:
Most definitively does(or should) fast idle when cold. Here's a snip of my old 650 starting when semi-cold on a cool(for SoCal) day.It has an enrichment mechanism for sure (the computer takes care of that),
but my idle speed is 1400rpm whether I start my bike in summer or in winter.
I ride 360 days a year.
2008 DL650 Fast Idle - YouTube
Nope; mine stays at 1400rpm no matter what.Most definitively does(or should) fast idle when cold. Here's a snip of my old 650 starting when semi-cold on a cool(for SoCal) day.
