My 2006 wee is well overdue for a valve adjustment, and the dealer mentioned that they may as well replace the valve seals as well. I have several questions on this topic (I am by no means anything remotely close to being considered a mechanic :fineprint: NOTE: My bike is working fine, no issues whatsoever and put about 10k miles on the bike each year. I've replaced the plugs with Iridium plugs and have about 50k of miles left on them.
Question 1 - The dealer said may as well change the valve seals when doing the valve adjustment. Is changing the valve seals really necessary? What is a reasonable cost to change the seals if being done while performing the valve adjustment? :yikes:
Question 2 - Aside from the obvious differences between a Wee's engine and the average automobile, etc. For a non-mechanic type "me", trying to understand why a wee / other bikes require a valve adjustment and automobiles "generally speaking" do not as a normal requirement for maintenance. It is about 4 hours of shop labor at about $85 per hour, so no small cost as you all know. I also have heard other's say it is cheaper to have the valve adjustment done than to pay for engine repair --- trying to understand why these engines are not built so this maintenance is not required. I have 120,000 miles on both of our cars / suv and have never had a valve adjustment done for either. Why is a valve adjustment needed for a bike / the wee and not for an automobile?
