1 - 6 of 6 Posts
I bought a barely used 2006 Wee recently (only 400 miles on it) and found it had rust in the tank. I've been riding it quite a bit recently, and it started exhibiting some very strange symptoms.
After riding for a while, the bike will start to "surge". I will have the throttle rolled on, but it will act like I just rolled off and the RPMs will dip drastically and the throttle simply won't do anything. Then all of a sudden the bike will surge ahead like I just gave it a huge rev. Once this starts, the surging continues until I basically put the bike away for the day and come back another day.
From doing various forum searches, it seems like it could be a throttle body issue, but with the rust in the tank, I am wondering if it is merely a fuel system issue and I need to clean out all the rust, check the filter, etc.
Appreciate any help!
Take care of cleaning the Fuel System before you worry about anything else. Chances are that will solve all the problems.
Is there a way to clean the fuel filter if rust is in it? From what I have been reading, it is nigh impossible to access the actual fuel filter itself...
Update:
So I took the bike over to the local Suzuki shop (Karn's Performance in Mechanicsburg PA), and they ran it through a battery of tests and found that the voltage was all over the place after running for a while. They determined it was a bad Stator and Regulator/Rectifier. All of those things sounded expensive, and they confirmed as much, so I drove it back 15 minutes to my place and mulled over what to do next. Upon said mulling, I decided what the hell, I'll have a crack at it myself.
I found a salvaged stator coil from an '05 SV650, and a salvaged Regulator/Rectifier from an '05 V-Strom. The total for both cost me maybe a little over $100. The actual job really wasn't bad, just took it slow and methodical. I had (still have) some concern, as neither component that I removed from my bike actually looked bad in any way but I also know electronics can go bad internally too so I might try to test them later at a separate point.
The little bit of riding with the bike went great, but I will have much more to do before I state it as a complete success!
1 - 6 of 6 Posts
