The most obvious thing to check is the rear wheel alignment as it is adjustable. You can check the marks on the swingarm near the rear axle but they are not always accurate. If both sides are in the same position, sight down the chain to see if the run is straight where the chain meets the rear sprocket. Various string and laser pointer methods can help too.
