Soupys
I found these to be the best because you can adjust them to your liking . I lowered my rear about 3/4 of an inch. Just stand your bike up straight and measure from a point you'll remember to the ground so you know where you started before you take off the stock links. After much experimenting I liked this height the best. I also lowered the front by raising the fork tubes 7mm in the triple clamps . 7mm is the limit because I have ABS and I think you can go 10mm in the front without ABS. Here's the link to Soupy. SOUPY'S MOTORCYCLE LOWERING KITS, HONDA LOWERING, KAWASAKI LOWERING, YAMAHA LOWERING, SUZUKI LOWERING, TRIUMPH LOWERING, SPEED TRIPLE LOWERING, STREET TRIPLE LOWERING, GSXR LOWERING LINK, GSXR LOWERING KIT, RAISING LINKS, RISER LINK, KAWASAKI ZX14 LO
