Vstrom 650 2016 startup issue
1891 Views 8 Replies 9 Participants Last post by  Recumbentbob
Hi,
Just tried to start my 650 from 2016, and it makes this sound when I try to start it up:
Video
Anyone had this issue or has any idea what it could be?
Many thanks
1 - 9 of 9 Posts
It sounds like the starter clutch (fig. 2) is not not fully engaging the starter gear (fig. 1) with the flywheel. It will only get worse until the starter gear's teeth are so damaged that it won't engage the flywheel at all, as well as damaging the flywheel. The starter is rebuildable.
Font Circle Auto part Drawing Line art
See less See more
Reactions: 1
Have you tested the battery and checked tightness of the battery terminals? That's where I'd look first since awful noises aside, it's cranking pretty slowly.
Reactions: 3
Hi,
Video
Many thanks
Hi,
Video
Many thanks
Hi,
Video
Many thanks
Give it a jump and see what happens .Battery sounds like its struggling.
Any work done to the bike before the sound on starting? Perhaps a stator replacement?
Sounds like a weak battery, jump or charge.
Sound like a weak battery or bad starter clutch. Does it do the same thing when you try to jump it?
Flat or dead battery.
1 - 9 of 9 Posts
