A few questions / tests to help for a better understanding of your ride's charging system:
Check that the battery conections are tight before taking any readings.
1) What is the battery voltage with the bike running over 3,000 rpm and no heated gear turned on? From 3,000 - 5,000 rpm, the charging system should show above 14 volts. Anything under 14 volts at that rpm you could have a burnt stator or faulty voltage regulator.
2) What is the total wattage of the heated accessories? Trying to identify how much load is placed on the battery / charging system vs no accessory.
3) What rpm are you powering up your heated gear? If at idle, you could be draining from a weak battery or weak charging system.
