Hi guys, have recently had a vibration noise develop over the last 24 hrs on my 2008 DL650. It sounds like a tinny exhaust baffle vibration when I hit higher revs above 7000rpm. I checked my skid plate, oil cooler shield, radiator shield and nothing is loose there. Any other ideas what I might check?
That's the motor. hahahaha Just being a smart ass. Sorry, but I couldn't resist. I've only had my Wee above 7k rpm once or twice so I'm not qualified to say what this might be, but being one of the original smart asses, I had to jump in...
We now return you to your regularly scheduled programing...
GIVI crash bars? Those are notorious for vibration, check the slip joint in front of the head.
Discussion Starter · #4 ·
I have the SW Motech bars but I will go out and tighten the bolts on them just to make sure. I gave them a shake and they didn't rattle but that might not mean anything. Any other ideas?
Hi Canadiandad ,
I'd recheck everything again using a rubber hammer ( just tap lightly ) shaking them will not make the parts vibrate like when the motor is running , also check the gap between the sumpguard and the exhaust header pipes you may have a stone jammed in there or the gap may be too small and they are hitting when the motor is running and the guard vibrates. I had to lower my sumpguard because of this .
Ozzy Strom
P.s. I'd check the rest of the exhaust / bike you may have a rock or something sitting elsewhere making the noise.
I had a similar noise that turned out to be the previous owner had left off one of the isolation grommets on the front right fairing.
