I would think a good welder could do the job. I'll seen these guys weld a beer can.
It definitely wasn't coming from the hose fitting -- it was seeping somewhere along the second "channel" from the top, but only when fully heated and pressurized.My '07 had a weep from the upper left corner and it turned out to be a loose clamp.
Did you pressure check the radiator prior to sending it off?
