1 - 3 of 3 Posts
can someone confirm if the 650 and 1000 rear shocks are compatible?...have a chance at re sprung and re-valved stock 650 shock that is suited for me and want to put in my '02 Vee... thanks!
They will fit, but the Wee shock is a couple on mm shorter, sprung lighter, and isn't damped as accurately due to being an emulsion shock rather than having the oil and nitrogen separate like the Vee shock does.
I can live with a few MM shorter..the difference will be made up in the lack of sag. the shock in question has been re-sprung and re-valved by Daughtrey's ... to same spec's I would have mine done to.... just wanted to make sure that they would direct swap hardware wise... thanks GW
1 - 3 of 3 Posts
