Clever Trail Desig-
Hey, that's some cool stuff you're working on! Thanks for posting.
I'm kind of struggling to find the "plush but firm" with the forks' stock compression piston, and I'm starting to wonder if it's possible to get there with the stock parts. I've gone even lighter on the compression valving, and it's not really going the direction it should. It's still stiff in some situations, but soft elsewhere. It's sometimes like this is the 4CS fork of the street bike world. (if you've ever ridden a KTM/Husky with a 4CS, you know I'm talking about) I realize that this fork is fairly basic construction and thus only has so much capability. For the price point of these bikes, we cannot expect to have A Kit type suspension.
Maybe the Gold Valve has more capability and I should just pony up. Or, I have a couple of fork compression pistons from an 03 YZ250F. Those pistons work very well if you valve one just slightly different than the other.
Bottoming cone elimination... Maybe you can add a rubber bumper in there to have a bumper stop fork- a little bit of rubber is better than metal on metal.
Perhaps, the newer Vee's type of fork was calibrated with the theme of stiffer dampening using lighter rate springs, as opposed to stiffer springs with lighter dampening. Dirt bikes used to be lighter springs with stiffer dampening 20 yrs ago. Look at how the dirt bike fork spring rates have increased over the years. .44 kg/mm used to be the stiff springs.
Are you planning to add a mid valve to the rebound?
Here is my current rebound stack and this seems pretty good. Nothing fancy, just stiffer throughout and seems to control my .95 springs pretty well.
Btw, my stock shims measured at .11 thk, at least by my digital slide caliper.
18x.11 w/ no slots
18x.15
16x.15
14x.15 (2)
12x.15
10.5x.3
18x.11 w/ no slots
18x.15
16x.15
14x.15 (2)
12x.15
10.5x.3
