1 - 20 of 20 Posts
Time to replace my tires again. The Battle Wings have about 10K on them & they are squared off from too many highway miles. I took a ride in the mountains of MA, & VT this weekend I felt myself in turns falling off that flat edge on the tire that has built up. Not to mention the two plugs I have in the rear tire have to go. Plenty of tread left but it's time.
It's been a few sets of tires since I have replaced the valve stems. I have had valve stems let go in the past. I was thinking of 90 degree valve stems like these below.
TB Discount Motorcycle Tires | Maintenance | Tune-Ups | Acessories | Brake Pads - Ariete Racing Valve Stems
All thoughts are welcome, open forum have at it.
Bill
I have been interested in the 90's myself so watching for info.
The straights can be a Pain in the Ass to check and fill when your in a hurry.
Mike
Banned
90 degree valve stems break more often than the straight ones; I'd just use a short straight stem.
Evolving Curmudgeon
I install bike tires for a living and replace stems on every tire change unless they are metal valve stems. The rubber pull-thru valve stems dry rot and crack at the base over time. The duck is correct about 90 degree valve stems being more susceptible to failing. They have much more G-force on them when the wheel is spinning then a straight valve stem. I also replace inner tubes on tube-type tires every time too.
My other bike has 90 degree valve stems. They break more often, partly because of the side pressure from checking and filling them. There is a plastic holder attached to the wheel to prevent them tipping too far but they still have a good amount of side to side movement. Also, if you plan to use Dyna beads, you can't get valve stem core filters for the 90 degree ones.
stems
We've got three spoke wheels, it's not like there is alot in the way of an air hose. Why ?
I've had bikes that were a real pain to get to the stems, not on this bike though.
Bill H.
Bill H.
Agreed. No need for the 90 degree stems, especially with that roomy 19" front wheel.
I install new rubber valve stems with every tire change. (Bikes with metal valve stems get new ones every three years or so.)
TR412 stems are a measly $1.29 each at any Napa auto parts, and the "valve fishing tool" to install them should be nearby for about $6 - $7.
TR413 stems also work fine -- they're simply 1/4" longer -- and are available in any Walmart or auto parts store. The TR412 stems can be a little harder to find.
Reactions: Tony D P
OK that some good input above. I just get the short rubber ones at napa & call it a day.
+1 on not using the 90 degree valve stems. It's a nice idea, but the centrifugal force loosens them and then they leak. Not fun.
Banned
+1 to what randy said: usea tire gage with a 90 degree bend; the digital ones are pretty good.
I also never fill up witht the water they provide at the gas station; I have a slime compressor on my bike and use that.
Correct me if i'm wrong but aren't Suzuki stems shorter than an off the shelf valve stem you would find elsewhere?
I always use Suzuki ones when i change them out, never had one fail though.
Yep. The rubber grommet that seals the metal stem to the rim dries out.
Discussion Starter #16
TR13's are in the bag. 3 bucks for the pair
Until we meet again
How necessary is the fishing tool? My Napa doesn't carry it so I'm wondering if I can just lube up the valve and push it into place.
I just screwed on one of these and pulled the stem into place with a pair of vise grips grabbing the tip.
Until we meet again
Perfect, I certainly have a lot of those around here after buying all that Ride-On sealant.
1 - 20 of 20 Posts
