Thinking about doing valve inspection/adjustment on my bikes which are Wee, 400 Burgman and 1800 Goldwing..............does anyone know if these bikes use the same type shim (same part number other than thickness)?
Thanks much.
All three use 7.48mm shims. A shim kit such as Hot Cams Valve Shim Kits - 7.48mm is usually used. Some dealers will trade shims. They are not usually bought by part numbers.
12892-05C00-120 is a 1.20mm shim.
12892-05C00-125 is a 1.25mm shim etc.
12892-05C00-160 is the largest listed in the fiche but I know they go up to at least 1.85mm.
A forum community dedicated to all Suzuki Strom owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, purchasing, reviews, accessories, maintenance, and more!
