So past few days been having fun doing a valve check. Took plastics and stuff off the bike Monday and hopefully fixed my coolest leak. Tuesday off came the tank and did the valve check on the rear cylinder. Went to put the valve cover back on and stripped the 2 bigger bolts that screw into the journal-cover. I put almost no force into these but thinking since I was using a 3/8 torque wrench its not as accurate as it needed tob e. but I am still suprised at how little extra force was required in this case to take out the butter they called metal. Doing some searching and its some what common, and most don't even get to the 10ft/lb that's in the manual. I also saw GrayWolf wondering how many do this. so figure lets post a poll about it. Who has striped these bolts and how did that fix them.
O the good news is that the rear cylinder is in spec. But bad news is yesterday was spent getting the heli coil kit and doing the journal-cover. So tonight I get to put the rear cylinder back together and check the front cylinder valves.
tho had some interesting info from suzuki yesterday. when I bought a new air filter yesterday, talked to the suzuki people and they said how they prevent this is replace the valve cover bolts whenever doing the valve check. they said the rubber is newer so more compression so takes up the torque when you screw the bolts in. Not sure I believe this but they did seam to believe it works. They also admitted that those bolt holes are like butter.
and option 3 should read "Yes, I stripped more then one valve cover bolt"
