Well I was checking the valves on my 2009 Wee with 16,000 miles.
I found both of the exhaust valves to be sitting right at the high end of the gap specification (0.30 ~ 0.33 mm).
Now I have always thought that the big issue with exhaust valves is that the clearance tightens up over time as the valves begin to seat. So you don't want to be too tight less the valve and piston decide to occupy the same space at the same time. Which leads me to a a couple of questions.
Is the DL650 motor a non-interference design?
I know when I worked for Ford it was an engineering standard that our engines be a non-interference type. If a timing belt should break you would not have the extra expense of replacing bent valves and cracked pistons.
Should I adjust the valves and let them seat more or is my logic about valve clearance getting smaller due to seating a bunch of horse hockey?
