1 - 13 of 13 Posts
I own a 2018 bl1000.
Should I really do the 20,000 km valve adjustment?
From experience, what are the chances that the valves are off?
After all it’s a pricy service ...
It's due at 24,000kms not 20,000kms as far as I know.
I got mine checked last week and pondered the same question. Most recommended doing the first check and if they are still in spec don't worry about them for a while.
It seems highly unlikely they are out, but it does happen. It was worth it for me for peace fo mind.
BTW, mine did not need adjustment.
Sent from my SM-T720 using Tapatalk
Do It
I had both my 2014 V2s checked and one had three tight valves and the other was in spec. If I had left them, I would have burned a couple of valves in the one. You think the inspection is pricey, wait till you start replacing valves. It just isn't worth it. Besides, who wants to be out in the middle of nowhere when things start going south. Grit your teeth and get it done, then you'll have piece of mind and a grin on your face!https://www.stromtrooper.com/attachment.php?attachmentid=256017&thumb=1
Different bike here , I have a 2017 wee with 15,000 miles and I am doing the valve adjustments right now. All four of my exhaust valves were at the minimum spec and all four of the intake valves are at the middle of their ranges. It is not worth the risk, get it done or do it yourself.
Do it yourself. Its easier for the DL1000 since you don't have to content with the cam chain. Just magic mark the position of both gears in relation to an easy visible reference point.
You can buy individual shims (if it needs adjusting) from Rocky Mountain ATV.
Do a coolant change at the same time. Front cylinder access is much easier with the radiator removed.
Checked my 2018 1000 at 16K. One was out and a couple were close. Adjusted 6 of the 8 to middle or more. I'll wait until 50 K (30K now)to do it again.
I'd say the first one is the most important one, they tend to tighten (exhaust mostly) the most during that first interval.
if you do it yourself and have to change any shims, make sure to measure and record all the shims sizes and locations so the next time you only have to mess with the cams once.
it's due at 24,000km not 20,000. My dealer recommended waiting to 30k as he said he's never seen one be out at 24k. I do my own work, and will do it around 29k as I have nothign better to do in the middle of winter haha
You are going to be looking at doing throttle body sync, spark plugs and air filter, as part of the service as well so if you are doing that it's not a ton more work to do a Valve CHECK. The adjustment is only if they need to be. Also tell them to reuse the gaskets, they will be fine.
I have no idea what the warranty is on your bike, but if you do not do the valve check, and you burn a valve after the check point while the bike is in warranty, I'm reasonably sure you would not be covered.
On the wee, the general consensus is that setting the valves at maximum clearance will preclude having to check them again for the first 100k miles. I did my wee valves at 30k miles and the exhaust were within spec on the tight side. I set all eight as loose as spec would allow.
I haven't done the research to determine whether this is the case on the vee (heavier valves). Anyone have a sense of whether this still holds?
Not to post a "he said the she said that she was told by a guy who knows a guy ..." but my mechanic said that the valve adjustments are, in his experience, generally valve "checks" because "most are in spec.
For the peace of mind, speaking only for myself, I would do at least the first one. However, bikes that bounce off the rev limiter compared to those that aren't generally rev'd out so much do seem to hold adjustment better.
Lest you think I practice what I preach (or post) I have three ATVs that get regular oil changes and the like but have never had a valve adjustment - and they're much easier than many bikes!
2015 DL650
Do it! There is a reason why the scheduled maintenance has you check the valves. Yes, very likely you dont have to adjust them. But, if they are out of spec get them adjuated before it becomes a bigger issue.
I remember my first valve check. I was anxious, but it got me very familiar with my bike. In addition you'll have the opportunity to do some other maintenance like flush the coolant system.
Cheers!
If you're not mechanically inclined, it would be a daunting job.
But if you want to give it a go, there is tonnes of help on this forum. You don't need any expensive specialized tools. That brings the cost way down to just your time and maybe the purchase of feeler gauges or something if you don't already have those (that's the cost of a few cups of coffee).
I would not worry about the exact mileage when you inspect but, rather, do it at a time that suits you and is at/after the suggested 24000 kms. I've checked mine 3 times in 205 000 kms. They were never far out and were fine at 24 000. I could probably have just left them unchecked altogether and still be fine. But, as someone earlier mentioned, you never know unless you check. You could probably do the first check, set them on the loose side of spec range and be done with it forever.
As for warranty, I think the only situation you might get bitten is if they turn out to be out of spec on a late first check. Probably they'll be fine and you can always ask the shop how they might deal with a situation like that before you make a decision. Any resulting problem would likely happen way after your warranty is toast anyhow.
1 - 13 of 13 Posts
