1 - 6 of 6 Posts
I am not real mechanical:headbang: so forgive my obvious ignorance.
When I read between the DL1000 (Vee) and DL650 (Wee) forums it appears that the Vee seems to require Valve Adjustments a lot more often than on the Wee.
I am curious as to why. Is it because of the torque and horsepower? Or is there a different design between the Vee and Wee valve arrangements?
Or Is it just my perception of what I read that the DL1000 requires more Valve Adjustments?
My DL650 at approx 49,000 was still dead center in specs when checked a couple months ago.
Thanks.
I last checked my valves around 190,000km, they were still good and have yet to have even one adjusted since new. :thumbup:
During the winter I will again check them.....
Cheers
Bigger engines have more valve contact area and more hot gasses moving through as well as heavier valves and valve springs. The Wee engine having a newer design might also be involved.
Greywolf -- thanks for the explanation.
I have been thinking about changing to the DL1000 and have been researching it abit more. Not wanting something too maintenance intensive.:yesnod:
Be aware it is easier to change the shims in a DL1000. The cam chain is not disturbed in the process.
1 - 6 of 6 Posts
