1 - 16 of 16 Posts
Hey guys,
I just got some hedienau k60s installed on my bike and I've been getting a whining noise coming from the front of the bike at highway speeds, only when I'm not on the throttle. Also at very slow speeds less than 5 when coming to a stop the bike shakes left to right slightly. This happens either when I'm applying the brakes or I'm coasting to a stop with the brakes. Could it be the new tires or is there something else wrong?
Personally, I would not run less than 36 psi in the front.
Also adding a wee bit of preload to the front will sometimes settle a little bit of nervousness.
But firstly confirm there is no underlying problem that has arose by coincidence at the same time of fitting new tyres.
A more aggressive tread pattern will most likely account for the noise you hear and might also account for the slight shake you experience but I would still check tyre pressures, wheel and headstock bearing's.
That's exactly what mine did when I put Heidenaus on it. The handling is also very different to the OEM tyres, it'll drop into turns, felt unsafe to me at first but after a couple of hundred km I've got used to it. Much nicer in the dirt. I recommend higher front pressure than standard. You have to put up with the highway noise and front end 'wobble' at very low speed.
I use them and love the K60's. Yes, they whine and sing (telling me how happy they are!). But, have no issue with a slow speed wobble, or high speed either. Something else is up. As far as the noise, I use ear plugs!
Something else is not up, it is your new tires. :wink2:
Did you read reviews before you bought them? They are notoriously noisy tires?
RE; the wobble. Is it possible that the tire bead is not fully seated all the way around?
Bikeless 4 now
That's why I went with the TKC-70's. A bit of dirt capability and great highway behavior so far. Plus no droning noise for thousands of miles.
In the last couple of years I've traveled all over on K60s and have had good luck with them, especially on stretches of gravel. I found that the noise dwindles some after about 500 highway miles. Never had a front end wobble that I recall. They do handle differently than most other street tires, though, and take time to feel confident with. They have some peculiar characteristics but I was happy that they got me from TX to Deadhorse, AK and back on various types of roads under less-than-ideal conditions at times. Usually ran 36-38F and 40-42R, fwiw.
With that said, I sort of look forward to spooning on a set of smoother running, more street-worthy tires for next year's paved adventures. Good luck sorting out your wobble issue. Others here have pointed out some things to check before giving up on your tires.
Discussion Starter #15
UPDATE
Thanks everyone for the suggestions! I did end up switching the tires to anakee 3s and they have been outstanding! So for now my k60s are collecting dust in my garage. Haha I essentially commute to work on it so I guess I should have bought a more road oriented tire in the first place. Thanks again for everyone's help!
And that is exactly what I've done. Waaay better on street and specially on the wet surface. Very capable and close to K60 on gravel. Cornering - day & night!
1 - 16 of 16 Posts
