1 - 3 of 3 Posts
I have found two plugs, one behind the headlight, the other above the horn. Eastern Beaver sells the plug above the headlight, but that one is connected to the ignition fuse 10 amp fuse. the other one is connector to the signal fuse 15 amp. So which one is to be used for the grip heaters?
The one with the orange/green hot lead off the ignition fuse is designed to handle the OEM heated grip set. The one off the all orange ignition hot lead is designed to handle a small accessory.
1 - 3 of 3 Posts
