I am planning on replacing my turn signals with aftermarket ones.
There is lots of information about doing the changeover and the types of turn signals to use.
The aftermarket signals I have have "bullet" connectors. Can you buy the Suzuki brand connectors somewhere so that I don't have to do a any more wiring than I need to?
Also, I'm not very electrically knowledgeable. Is there a name for the connectors?
I'm not sure, but check with Eastern Beaver Products..........he might produce a little pigtail adapter?? I know I've seen some on the internet somewhere???
See if "Suzuki Turn Signal Wiring Harness Connectors Adapter Plug" on eBay look right. $10 delivered. Buell turn signals are often used as replacement for Suzuki signals.
Be sure the signals you use for the front stand away from the headlights enough to get noticed by the half of the drivers who even try to notice us.
I got mine from Ebay.
If you are going to LED turn signals you can get the LED flasher from Ebay too.
