I mentioned this in another thread, but I think it's a different problem so here's a new thread. This pertains to a 2004 DL650
After a wreck that mashed up the front end of the bike (including the instrument cluster) the turn signals/emergency flashers will not work when the key is "on" but they do function properly when in "park". As expected, the liscence light only comes on in park as well.
After looking at the wiring diagram, I tested the voltage on the O/R wire from the ECM that goes to the ignition switch. It's about 5V, which seems like the problem since I assume it should be 12V (I have just about no idea how the electrical system works). Any ideas? Is there some sort of workaround that would get the signals working while the bike is on?
