A TRE is connected in the wiring to the gear position switch which is directly under the front sprocket.
How can I make a de-restricter for my DL1000? shows how to make a TRE. Hopefully, yours has connectors installed so it can just be unplugged from the stock connectors and the stockers rejoined.
Old post, I know - but I'm I've got a new (to me) '06 DL1000 and apparently failed at making my own TRE - based on that post at vstrom.info.
I'm wondering if I had mine installed backwards.
From that picture, it was my understanding that the gear signal comes in from the right side of the plug and goes out to the left to the ECU.
But, if the gear position switch is under the sprocket cover, wouldn't the signal enter the plug on the LH side, and go to the right side?
When I had mine installed, the OD light did not come on. But, after a few minutes of riding, the warning light came on and "FI" started flashing.
I took it back off, the OD light worked again, and I got no errors.
TL : DR version - Does the signal from the TRE need to go left or right - assuming you're looking at the plug from the behind the tank, facing the front of the bike?
