1 - 2 of 2 Posts
All of a sudden my rear traction control is super sensitive. It's flashes in 2 and a little in 1. It's not very intrusive but flashes mid range.
I took the wheel off a few times(tire and sprocket swap), last time I forgot the abs sensor. I removed it before putting the wheel back on. Looked fine.
Sent from my HTC6500LVW using Tapatalk
Check the ABS ring for any dents, both front and back. If it gets dented or bent it can throw off the sensors.
I had trouble with my ABS from that before, straightening the ring corrected it.
I have my TC turned off all the time these days, I see little benefit in it.
1 - 2 of 2 Posts
