Will some one post photos of the TT shift lever on a DL1000? Also what is the lenght from the center of the splined shaft to the center of the shift peg?
Thanks in advance, appreciate your help.
Distance from centre of spline to centre of shift peg is approx 110mm.
If you are planning on installing one, slightly open the gap to make it easier to fit over the spline as you will be taking it on and off a couple of times before you get the position to suit you best, do NOT tighten it up until you are happy with the placement.
On mine, the peg ended up in exactly the same position as it did with the stock lever setup.
Also, I rode around for a couple of weeks with the unused linkage pivot just sitting there before I noticed that it unscrews... :headbang:
1 - 4 of 4 Posts
StromTrooper
A forum community dedicated to all Suzuki Strom owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, purchasing, reviews, accessories, maintenance, and more!
