1 - 14 of 14 Posts
Well, I was adjusting my clutch lever tonight before removing my gas tank, and it happend. . . :evil:
The wrench slipped and hit the tank. :cry: Saddly it took a small chip out of the tank (all the way down to the metal). I was so pissed! I looked through previous posts and have not found much information about touch-up paint. The only name I have really seen is Color-Rite. Does Suzuki not have touch-up kits available? Is it best just to go to a body shop and see if they can match the paint and give me some? Will I need to prime the small area and clear coat it after I paint it? I would appreciate any suggestions.
stroms have a triple paint so very hard to match for what I was told, but u should put ride way some rust proof.
touch up Paint
Apparently Suzuki paint colors are proprietary. You won't find a Dupli Color spray can at your Wally World or auto parts store. Instead, try a NAPA auto parts store if they're in your neck of the woods. One of their stores in my area (NE New York) has a paint department that will mix custom paints, just bring your bike in and they'll analyze the paint with their computerized strobe gun. It's as close as you'll get other than color-rite (?) which is quite expensive. The first chip hurts the worst. Good luck with it!
Thanks guys. We do have NAPA stores out here, but they do not mix paint. They only have the DupliColor like Wally World has. Oh well. I spoke to the guys at the local Suzuki shop and they said they can get a touch-up kit for about $50, and it is from an outside source b/c Suzuki does not do their own paint apparently. Then one of the guys said when he use to work on customs, he would go to the local nail salon and have the ladies there mix up some nail pollish to cover any chips. Now that sounds redneck, but darned if I didn't try to stop at a salon on the way home (they were closed). :lol:
To get a mix you have to find an auto body supply shop. I've done it for a van with have, with a three part color / metallic / clear paint system. The paint is 25 or so for a can.
I suppose the other place to try is a model shop.
THis past weekend I was reinstalling the stock bars (long story) and did the same exact thing- dropped the wrench and chipped the tank.
Oh well, other than dropping it, it is now initiated. Still pissed me off.
Color Rite has the exact touch-up paints. Quick delivery too!
Cheers
Banned
Touch-Up Paint Jobs - Beware
Touch-up paint jobs on these motorcycles has to be one of the most insidious traps that someone can fall in to. When someone scratches their beloved motorcycle, they may desperately want to return the bike to its original condition, but this may be more difficult than they first imagined.
I’d like to relay some rather painful lessons I learned from a recent episode where I scratched one side of the fairing on my new bike. Hope this helps someone else.
Lessons Learned:
1)Touching up just one portion of a part leaves a rather ugly line(s) where the new paint meets the old paint. When you’re preparing the surface for painting, you won’t be able to sand a perfect line either, at least not hand sanding. With hand sanding, you may find yourself sanding down a larger & larger area as you accidentally intrude on to undamaged paint areas with each stroke. As for sanding out the line after the painting is done(as I was told was possible by the people from Color-Rite), this did not seem to be possible as you wind up scratching the undamaged paint on the outside line, allowing it to be only ‘just so good’. I also had to wait 5 days for the paint to cure before removing the masking and attempting to sand out the line.
2)Mixing small quantities of paint in the hopes of matching the original paint, even if computer color coding is used, is unlikely to produce a good color match. I tried this at NAPA and when it dried it looked burnt orange, clashing with the Pearl Crystal Red OEM color of my bike.
3)A tri-coat of base, color, clear(and perhaps primer) was need to match my OEM color. Off to Color-Rite since no one else seemed to have it. I’m not even sure Suzuki sells touch-up paint. And about the primer I just mentioned, don’t think you can use just any primer, either. You have to at least match urethane paint to urethane primer(and there may be other compatibility issues) otherwise a disappointing chemical reaction might occur when you start applying base to the primer which causes the paint to kind of glob together rather the cover smoothly. I choose Color-Rites primer just to be sure I would avoid any compatibility issues.
4)Even if you go the color-Rite route and buy 4 aerosol cans(primer, base, color, clear coat for about $200 which would at least do you an area about the size of the gas tank) you still might not end up with that smooth, exact match finish that you seek. To avoid having a line(s) you’re going to want to do the entire part. Easier to work with if you take it the part off the bike, but not impossible to do some parts with masking tape, newspaper and a drop cloth. I tried the markers, small brush containers and did not like them. If you’re a skilled painter with a spray gun, good place to work, good tools, knowledgeable about painting, etc. you probably could do better than I did. Color Rite said sometimes there are problems spraying the Pearl Crystal Red(sparkles like it has flakes) from paint guns.
5)Nail polish is a cheap and simple solution, but may be globby and not match the color to satisfaction. Nail polish may be removable though if you tried it and did not like it--provided you use the right stuff(rubbing alcohol ?). Putting a new decal over the scratches, if possible, may be easiest and most cost effective route.
Painting Options likely to work:
1) Buy the entire piece(fairing, etc.), decals, etc. from the dealer and transplant any emblems salvageable from the old piece. Not cheap for some people, but it does ensure an exact color match with the other parts of the bike.
2)Paint the entire bike(the necessary matching parts of the bike, that is.)
2)Go to Color-Rite and buy the expensive paint, but this still is by no means a guarantee that you’ll get the results you expect. There’s skill involved painting and plenty of details I’m leaving out here(e.g., how long to wait in between coats, what temperate to paint at to avoid runs, etc.)
My paint job isn’t hideous, but it sure wasn’t the results I wanted, particularly with all I went through. My bike was pretty new when I scratched it and it was so hard not want to make it perfect again. My unwillingness to accept that I could not make it perfect again was what drew me into this whole, rather nightmarish, educational, painting episode. I may someday buy the entire fairing panel from Suzuki, and put whatever decal I want on it, transplant the emblem, etc. but that would not make sense unless I am sure that the new Hepco & Becker crash bars I installed would protect it perfectly.
From what I understand, touch-up paints are just that; for small stone chips, etc. If you have major damage, yes, you will have to take the panel down and respray it, unless you're really good at body/paint work. It is possible withi base/clear paints to touch up an area of the base and then blend the clear coat. It takes a lot of wet sanding and patience. For what it's worth, I've seen my dad take house of color translucent candy paint with a noticeable sag in it, and blend it to where it looked perfect through a process of sanding/recoating. It's not easy, but it can be done.
Ship to Aus!
This is exactly what I need! It appears that ColorRite don't ship to Australia, do you know how it can be obtained in Australia?
I've actually used nail polish as a touch up paint for small chips. If you ever look through a nail polish display in a store, you'll see a pretty wide selection of colors, one of which may be a close match for your bike's color. The nail polish sticks really well, is cheap, comes with a fine brush to apply it, and will at least protect the metal from rusting.
1 - 14 of 14 Posts
