1 - 10 of 10 Posts
I know I'm being lazy but I'm tight on time, can anyone give me the torque specs for the front & rear axles on 07 1000. Also the sinch bolts for front?
Thanks!!
My axles are in great shape, just waiting for tires to come in tomorrow. & reassemble. Thanks for the help. getting rid of the shinkos and getting some Michelins
So I should not grease the axel? It had a light coating if grease when I pulled it off the bike.
That's okay if you choose. It will insure the axle stays free of the bearings but that shouldn't happen because the axle is stainless steel and won't deeply corrode. The important part is to use anti seize on the axle threads to prevent galling between the axle and axle nut and reduce the torque to 58lb-ft to account for the lubrication effect.
1 - 10 of 10 Posts
