Does anybody have the torque values for the front axle and brake calipers? Is anti seize a good idea on the axle threads, or clean and dry?
FSM Calls for
Front Axle/47 Ft Lbs
Front Axle Pinch Bolt/16.5 Ft Lbs
Brake Caliper Mounting Bolts/28 Ft Lbs
Reactions: OliverWinn
There is no stainless on stainless so clean and dry is fine. Anti seize would be okay on the axle if the torque was reduced to about 80% of spec. and the pinch bolt would keep the axle from loosening anyway. If anything, I would put blue Loctite on the caliper bolts.
In case anyone stumbles upon this thread, I don’t think that axle spec. is right. Better double check.
