1 - 12 of 12 Posts
Initial report
I am pleased
Can be seen with direct sun on its face
Broad blue path big arrows easy to see at a glance
Count down distance to next turn etc.
I haven't used the routing extensively but seems fine and there is the on screen editing of a route in english so should be modified allowing you to change along the way
Thanks for mentioning this GPS I hadn't heard of it. I've been wanting to upgrade from my automotive Garmin but didn't want to pay the Zumo price. Are you able to transfer custom routes from google maps?
Does anyone know of a GPS (other than the pricey Zumo) that will pair via bluetooth with a Scala headset?
I use tyre which is a skin of google maps
TOMTOM RIDER2 is designed to pair with Tyre. tyre make routes just point and click
Rider2 pairs sound with blue tooth but homey do do dat so no direct knowledge referencing Scala
Google Manuals and you can download the rider II manual and see
<this thread probably belongs in the gps sub-forum here, but...>
I recently picked up a Tom Tom Rider for $330 and it has taken me a couple of weeks to decide that I will actually keep it.
Pros:
The winding roads feature is awesome and is the primary reason I am keeping the unit. It puts me on roads that I am unfamiliar with that are fun to ride. That alone is worth the money for me.
Routing works fine.
Bluetooth works pretty well. Paired easily with the iphone and Sena.
It's waterproof and the screen is not too hard to see in sunlight.
Cons:
I often listen to Pandora and the Rider will occasionally cut in but not say anything - when it does cut it in the volume is way louder than necessary, even when volume is set to low.
The large size/weight makes it shake a little more that smaller/lighter units - but the Zumo's are getting bigger also.
Usability is not as good as Garmin when using the unit to look around on the map (i.e. to figure out where to head next, etc.).
Zooming/painting of the screen is slow compared to Garmins - even my olders Nuvis.
Level of detail on screen is less than Garmin.
Map cannot be set to 'north up'.
City names come and go when you zoom in and out. They are there at some zoom levels and not there at others - very annoying.
TomTom uses Tyre for navigation software and that is PC only... I'd need to run a Windows VM to use it on my mac...
That's a bunch of cons, and there may even be others, but for me the winding road feature makes it all worth while.
In my opinion the Tom Tom Rider is not as nice at the Zumo, but for less than half the price it does what I need it to do. I can use my iphone when I want to look at maps in any detail. And if I need hands-free navigation on the fly I can talk to Siri and just use the Rider as a visual aid.
If the new Zumo 590LM supported voice recognition over bluetooth, I may have dropped the $800 on it, but without that feature I can't justify that much money on a gps unit. The voice recognition on my Garmin 3597 in my car is awesome. I want that functionality via bluetooth in a Zumo for hands-free navigation while on the bike.
But for now I will stick with the cheaper Rider and use Siri for hands-free navigation if/when needed.
I am just now considering this newly upgraded version of the tomtom. I had a refurbished tomtom rider which I believe was the version 3 currently discontinued but still found on Amazon and eBay sometimes.
I do have a question for those that have the new unit though. I notice that there is no SD card slot on the new unit as opposed to the old version that had that available. How many custom routes can you create in tyre and upload to the new unit? This is pretty much my deal maker/breaker on the purchase decision.
Sorry no idea
Some specs are on the website and the manual can be downloadable
Memory is cheap but I also know some tracks get to be huge and over load my Garmin Oregon,
I use mine for exploring
Map source ?? delorme etc. to tyre then to the routing but I have not made it a habit of saving anything.
Make waypoint on the next road and periodically on a long twisty road then done
I believe my success will be in the ability to alter the route when I want on the go
One NEVA the route turned into an abandoned cow path. Once the route was broken there was NO going back
This is what I did.
Here in OZ the electronics stores have most of the units out on display and powered up so you can try before you buy.
I took my helmet into the store and paired my headset with the units on display and tried them all out.
With my testing Garmin were the only ones that did not give instructions via Bluetooth, all the Tom Tom & Navman units I tested did.
Excellent research, Rolex. Thanks for that.
Finally got out
Tried winding routes
Seemed to work well, picked some nice roads and avoided congested areas and towns
I think most would be pleased if owned Strom
If you don't think you are a good navigator then I can recommend this TOMTOM Rider
I have some good routes in my repertoire over the years and the TOMTOM replicated it bang. Nice 2 lanes and avoid congested areas
It also followed the tyre route very well only 1 minor hick up
1 - 12 of 12 Posts
