Thanks guys,
20 reply's in 24hrs. A lot for me to work through. But, OK yea will work on my standing.
It's not so much the standing but the control of the bike when standing, I can stand for 20 mins at a time, no problem- on the arches, a good lean in, egs a bit bent. But coming up to a gravel turn, needing to gear down, shift weight to the outside, and then get the smooth acceleration through the turn as you hit a bump, all while standing thats a bit tougher :-/.
Accidental throttle twists on the rough when standing is also something I will need to figure out how to stop.
I'm just shy of 6ft, and have the bars risen as much as possible on my '13 without changing/reworking cables.
How hard is it to lower the pegs? If you lower them doesn't that mean they can then scrape on the ground as you lean through a corner on tar (has happened once and scared the hell out of me).
Thanks for all the technique tips, will work through them.
Have a good Xmas fellas.
Matt.
Matt.
