Am going to be needing new tires and since 95-98 % of my riding is on pavement I am looking to go to a more touring / mileage tire. So here is the ? The front calls for 110/80R-19, I have found a 110/90H-19. So how much lee-way is there regarding width/aspect ratio/ speed rating to play with in general. I believe the H rating is actually higher than the R but really unclear as to how much a 90 vs 80 factors in. Appreciate the input.
A 90 is a taller aspect ratio than an 80. The tread to tread diameter of a 90 would be larger. A Bridgestone Battlewing, Pirelli Scorpion, or Continental Road Attack 2 are well known street tire brands that will fit perfectly and are presently available. 90s would probably work fine though.
There seems to be enough gap under the front fender to permit the 110/90 to fit - and I have heard of people running that size (but can't remember what brand).
There isn't much clearance with the standard tyre (little more than 15 mm) and that could be a problem, as different manufacturers / different categories may be slightly taller than the "nominal" 110/90 that you mentioned. A tall-ish 110/90 might not actually touch the fender [when stationary], but might grow a shade taller with the centrifugal force at high speed of revolution.
The other problem with minimal tyre-fender clearance is that your wheel could seize up after gaining only a small coating of mud [on wheel and/or inside of fender]. You may have the best of intentions that you will never be going off the bitumen - but sometimes these unintended events come to pass, even if just a few dozen yards of muddy access road. And your first warning of the mud build-up, will be your front wheel skidding out from under you. Uncontrollably !
A similar problem can happen when a piece of gravel gets flung up under the fender (or carried up, stuck in a groove in the tread).
These sorts of problems can still happen with the standard-size 110/80, but at least there you have a much larger safety margin.
* The 110/80 R 19 should, by rights, be using the "R" as referring to Radial Construction (rather than the R speed-rating of 170 kph / 106 mph).
Close by that size information will be the load & speed rating - expressed as something like "59V" or "60H" or "62T" or somesuch alpha-numerics.
A 110/90 tyre, being bigger in height & volume, will hold more air and therefore carry a higher max load than a comparable 110/80. So it may well show a higher load rating than "59". But higher than the (stock) "59" is of no real benefit for a front tyre.
