1 - 2 of 2 Posts
I'm in the process of buying my first set of replacement tires for my '08 Vee.
As I look online at my options I come across tires sized with either metric or standard sizes.
What is the standard equivalent of the Vee's factory tire size?
110/80 R19 front
150/70 R17 rear
Will any other sizes fit?
Thanks for the help!
Tyre list for the DL650A-K8
You have an extensive list here.
If you keep your original wheels, stay with the same recommended size. The question you should ask yourself instead, is what type of tyres you like, how much off road driving will you do? Maybe a plain street tyre is your best choice. I will still drive on gravel, as I have plenty of unexplored forest roads to drive. Therefore I've recently chosen Michelin Anakee² as my second set.
1 - 2 of 2 Posts
