1 - 20 of 43 Posts
I got a nail in the back tire of my Vstrom 650. This is a new bike with only 1300 miles on the tire. I started to just buy a new tire but have been thinking about trying a product called Stop and Go plug kit. I was just wondering if anyone has tried this plug kit. I have plugged tires before but just as a temporary fix until I could get home and replace the tire.
Kevin D
You're gonna get the full gamut of replies on this question, ranging from "you'll be fine" to "Don't do it unless you want to die!" Reality is that it depends on the type of tire (steel cords are tougher to plug than aramid/polyester cords), location of hole (center of tread vs near the sidewall), size of the hole, and your skill/experience with the plug kit. Honestly, if the tire has 50% life gone, I wouldn't risk plugging a tire for only a few thousand miles of riding. If it's a brand new $180 tire, I'd certainly try it. Your other option is to demount the tire and use a patch or take it to a tire center and have it professionally repaired. Most places won't repair a MC tire "OFFICIALLY" but if you simply carry it in and do it on a cash basis (no receipt) they'll do the repair.
I've done it both ways--plugs and patches--and run the tires for thousands of miles until the carcass was done and had no problems. I had one tire with steel cords in the tread that I was never able to repair without a slow leak. Try it and see.
Well said.
I wouldn't use the Stop & Go plugs for a "permanent" solution. The worm plugs work better.
Horizons Unlimited makes an excellent video about bike tires and their repair. I watch mine over and over.
I tried repairing my last flat, on a similarly 'new' tire. The thing was, which I did not know at the time, the hole in the tire apparently went into the carcass at an angle, so when I inserted the tire plug metal shaft thingie, I pushed and pushed to no result. I thought it was the belts resisting the tool, so I redoubled my efforts and promptly broke the tool tip off INSIDE the tire carcass......yup, that ain't coming out ever....
I really messed that one up....ended up buying a new tire, but I at least tried to repair it (it was freekin' brand new!)
I think you're paying for more than you need with that Stop and Go kit. Advance Auto, NAPA, AAA Auto, etc all sell tire plug kits for far less.
I wouldn't hesitate to plug a tire (especially a new tire), unless the hole was too close to the sidewall. The worst case scenario is that the plug will leak and you'll have a flat tire again, at which time you could bite the bullet and get a new tire.
What supatramp said.
The stop and go is pricey, hard to use and fails easily, in my experience. Worms are cheap and easy to use and worked mo bettah.n Oh, it helps to have a pump with you too.
I've successfuly used the "worms" for five different repairs on bike tires, and one on one of my cars in the past. These repairs were essentially permanent as I used the fixed tires for many thousands of miles afterwards with no issues.
Banned
stop n go = heavy, pricy, and doesn't work well. In fact, I bought one I will never use again because the worms work so much better..... want it?
I was just about to post the same thing. Stop-n-Go plugs are utterly useless, fraudulent shite.
I've had excellent results with plain old low-tech sticky string repairs, as long as the tire isn't damaged too badly.
I've also repaired a few tires with plugs inserted from the inside with excellent results as well. You do have to make sure you prepare the area correctly -- rough up the rubber on the inside and clean it thoroughly.
If you're unsure or the puncture is large or at an odd angle or not in the tread, then the safest course is always to replace the tire. Painful, but sometimes that's just what happens.
I carry Nealey sticky string plugs -- they're skinnier and don't need added glue (which is always dried up when you need it). The way you install them basically ties a knot inside the tire. Regular sticky strings from any Walmart or gas station work fine as well.
Nealey Tire Repair Kit - Repair Kits
I've heard many a report that most times a sticky string plug will work just fine. Better yet, consider it a temporary fix and get a plug patch installed from the inside, or even just a vulcanized patch. I'd be very confident with either of those.
Another vote for the Nealey tire repair kit. No glue required and the plugs are just about bullet proof. The worm kits from the automotive store work really well, you just need fresh glue (not guaranteed after a few months in Phoenix heat).
Plug it ride it and don't sweat it. Just use the regular ol tire plugs as stated above. Stay away from the "special" tire plugs.
I just yanked a six inch nail out of my tire today in he REI parking lot. Threw a plug in it aired it up with my 12V compressor and was on the road in less than 10 minutes from the time I started the operation to having my visor down and rolling away.
You can get everything you need to perform this operation for less than 20 bucks from Wal Mart. And it can keep your day from ending :thumbup:
tire
Kevin D
picked up a nail with 120 miles plugged it 2k miles ago ill get a new one around 4k im still here
I've done the same thing with a car tire, took out the piece with needle nose pliers and shoved a worm in and drove til I needed new tires due to tread.
I got this guy in my brand new Anakee3, put a worm in it and rode through the entire AZ summer with no issues. Check the plug every now and again and keep a slime kit(grab this regardless of whether you decide to chuck the tire or not) under the seat. A trick I picked up is to use a lighter on the worm after the hole is plugged, then let it dry and cut off the excess. I haven't had a plugged tire fail on me yet(knock on wood.)
Yep another vote for "strings" repaired and never bothered getting a permanent repair done and never had an issue.
I've always used a compressor, but anyone used CO2 cartridges successfully?
I carry a Walmart air pump by Slime and strings with me under my seat.
Pump was $10 and kit less than $6 so for under $20 I should be able to take care of a simple puncture.
I think If I was on Pee Wees big adventure I would go Heidenau's with Ride ON in them
Discussion Starter #20
Thanks everyone for your help. I think I am going to look into buying a new tire because I am traveling about 90 miles round trip every day and it will give me a piece of mind.
Kevin
1 - 20 of 43 Posts
