So after hurting my back I desired to breakdown and have a shop change my oil. They came back showing me I needed new tires. Thought I would get more than 9800 miles on my stocks but anyway. The back tire tread I am not surprised on but the front had even wear. The left side had a "wave" pattern and I was told that's way when I lean left I feel the bike pull a little. Now is this common or is this an issue with my riding?
Sent from my iPhone using Motorcycle.com App
Tire wear depends on inflation, road surface, riding style and temps
Tires wearing out is a by product of traveling miles.
Some get better mileage out of the same tires than others.
I wear mine out on the sides before the center tread. I hate when that happens.
FWIW, my stock DL1000 rear lasted 5,000 miles. Front lasted 8,500 miles.
I am pretty easy on tires (I'm not a wheelie, burnout, fast stop/start kinda guy). I run 36PSI front and 41PSI read.
My Tourance tires do much better.
Motorcycle tires always wear more in one side than the other -- it's not your riding style.
The cause of this pattern is the subject of much debate, most of which is downright brain-damaged.
I have no idea which hare-brained theory is correct (and it doesn't matter in the least -- when your tires are worn, replace them), but here's one page with lots of info and tests and pseudo-scientifical blather.
Motorcycle Tire Wear
Roads are crowned to force drainage to the curb
A Your bike is therefore always loaded on the left side of the tire
B The crown also acts as banking so right turns are positively banked where left curves are not and you will get more scrubbing of the rubber.
Find a member in England and swap tires, his are worn on the right side
I was just wondering "why" my rear tire showed significantly more wear on the left. THANK YOU for explaining that. So very timely for me.
9800 miles
That's about right for the Trailwings. I switched to Metzeler ME 880 tires and get about 12-13K out of the rear before it is gone. A little more expensive but the performance improvement is worth it to me. Expect your chain to go at 16K and the sprockets at 30K. Always upgrade to better-than-stock on these items.
F: 120/70-19
R: 160/70-17
